How to play DSD files when use the FiiO DAC for Windows computer?FiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:138
Reply:31 Read:106027   2021-05-28 11:06:12
Here is an example of the KA1 using foobar2000 on Window10 computer.
Video:
Precondition:
a.Connecting the KA1 to the computer, and select the 'FiiO K series' as the default output device on your computer.
b.The FiiO USB DAC driver(Download link: Click here)should already be installed on Windows computer.
Here is the instruction about how to install the USB DAC driver: Click here
1.Please download foobar2000 install pack: Click here, and unzip it on the Wins computer.
Then double click 'foobar2000_v1.6.10.exe' to install the foobar2000 app first.
2. You could find that there are also some application plug-ins in foobar2000 install pack. And the certain ones should beinstalled firstly.
① ASIOProxyInstall-0.7.3.exe
② foo_out_asio
③ foo_input_sacd
④ foo_input_dsdiff
3. From File-Preferences-Components page in foobar2000, click Install and select all the components in the foobar2000 install pack, then click button OK to apply the change.
4.  Double click the file ASIOProxyInstall-0.7.3.exe and then approve this installation. Please click button Next and then click button Install to install ASIO Proxy for foobar2000.
Now go to File-Preferences-Components page again. We will find the foo_out_asio, foo_input_sacd,foo_input_dsdiff componets have been added successfully. In output page, ASIO: foo_dsd asio option is added.
5. Select Device: “ASIO:foo_dsd_asio” (Files -> Preference -> Playback-> Output)
6. Please make some changes on ASIO Proxy 0.7.3 pop-up window(Files -> Preference -> Playback-> Output-ASIO)
For KA3, please make some changes on ASIO Proxy 0.7.3 pop-up window according to the following picture.
7. Change Output Mode: DSD (File-Preference-Tools-SACD)
8. After finishing the above settings, when DSD playback,foobar2000 shows playback status as below:
The current sample rate in the FiiO Control Panel will shows the sample rate of the DSD file:
And you will find the colour of KA1 indicator light will change to green. Then you can start to enjoy the music with DSD format by KA1.
31Replies Positive Reverse  GO!
