UTWS17-firmware downloadFiiO Community| FiiO forum| FiiO product official communication platform
Reply:0 Read:62   Thu Nov 05 17:58:03 CST 2026
UTWS17 Firmware Upgrade Guide
The UTWS17 firmware can be upgraded through the FiiO Control app (or FiiO Music app). Both online and local firmware upgrades are supported.
1. Online Firmware Upgrade
  1. Make sure your smartphone is connected to the internet.
  2. Open the FiiO Control app and enter the UTWS17 device settings page.
  3. Tap the gear icon in the upper-right corner to access Settings.
  4. Select Firmware Upgrade → Online Upgrade and follow the on-screen instructions to complete the upgrade.
2. Local Firmware Upgrade
  1. Both Android and iOS devices support firmware upgrades. Make sure FiiO Control is installed on your smartphone.
  2. Download the firmware upgrade file and copy it to your smartphone.
  3. Open FiiO Control and enter the UTWS17 device settings page.
  4. Tap the gear icon in the upper-right corner, then select Firmware Upgrade → Local Upgrade.
  5. Locate and select the firmware file you copied to your smartphone, then follow the on-screen instructions to complete the upgrade.
Important Notes
1. Both earhooks must be connected
Before upgrading, make sure both the left and right earhooks are connected to your smartphone. You can check their battery levels in the FiiO Control app to confirm their connection status.
Both earhooks must be able to play audio normally before proceeding.
You only need to perform the firmware upgrade once to update both the left and right earhooks.
2. Remove both earhooks from the charging case
Before upgrading, remove both earhooks from the charging case.
Do not perform the firmware upgrade while the earhooks are inside the charging case.
If the earhooks are upgraded while inside the charging case, they may enter charging mode during the restart process and fail to return the required response to the app, resulting in a firmware upgrade failure.
3. Individual earhook upgrades are not supported
The left and right earhooks cannot be upgraded separately.
If the two earhooks have different firmware versions, the device must be returned to FiiO for servicing.
Updated at 2026-11-5
The following changes and improvements have been made in the new firmware:
Note: The UTWS17 firmware upgrade requires FiiO Control V4.7.1 or later. Please update the app to the required version before proceeding with the firmware upgrade.
1. Added support for Bluetooth 6.2 protocol stack.
2. Fixed the issue where the device would restart during LE AUDIO playback.
3. Fixed abnormal battery level display after connecting to a phone.
4. Optimized the low output amplitude issue when connected to certain phone models.
1.新增支持蓝牙6.2协议栈
2.修复LE AUDIO播放重启问题
3.修复连接上手机后电量显示异常的问题
4.优化连接部分手机后输出幅度偏小的问题
注意:UTWS17 固件升级需要搭配 FiiO Control V4.7.1 或更高版本才能进行,请先将 APP 更新至对应版本。
UTWS17 v0.62 download link: Click here
