How to Update the Firmware on the DT11
1. Online Update
Connect the DT11 to Wi-Fi. If a new firmware version is available, an update notification will appear in the notification bar. Tap the notification to enter the firmware update page.
Alternatively, go to Technical Support > Firmware Update > Online Update, and tap Check for Updates to manually check whether a new firmware version is available.
2. Local Update
Download the latest firmware package from the official FiiO website and copy it to the DT11's internal storage or microSD (TF) card.
Then go to Technical Support > Firmware Update > Local Update, locate the downloaded firmware package, and tap it to start the update.
There is no need to extract the firmware package before updating.
Make sure the DT11 has sufficient battery power (above 30%) before starting the update to prevent update failures.
If the device enters Recovery Mode during the update and cannot detect the firmware package, the package may be corrupted. Press the Power button to confirm, select Reboot to restart the device, then download the firmware again, copy it to the DT11, and retry the update.
Updaed at 2026-10-23
DT11 FW1.0.2 firmware changes are as follows:
1. Added support for Baidu Netdisk and OneDrive playback in FIIO Music.
2. Added sample rate display in the USB Audio output status bar.
3. Added third-party app background standby optimization and auto-start management.
4. Added option for the FIIO Cast app to start on boot.
5. Fixed an issue where USB exclusive mode was not released after the exclusive app was closed from the background.
6. Fixed occasional abnormal noise at the beginning of track switching when using USB output.
7. Fixed occasional unresponsiveness caused by focus issues with the track skip buttons and play/pause button.
8. Optimized indicator light display logic.
9. Optimized FIIO Music USB exclusive mode compatibility.
10. Optimized the popping sound when switching tracks after enabling All To DSD.
11. Other performance optimizations and bug fixes.
1. Cloud storage playback: Go to FIIO Music->Media Server to log in and use.
2. FIIO Cast auto-start on boot: Go to the FIIO Cast app->Settings to enable.
3. Third-party app background management: Go to Settings->Battery->App Standby Optimization and Auto-Start Management, enable one-click optimization for all apps and disable auto-start for unnecessary third-party apps to effectively reduce standby power consumption.
1.新增飞傲音乐支持百度网盘、OneDrive网盘播放
2.新增USB Audio输出状态栏采样率显示
3.新增第三方应用后台应用待机优化和自启动管理功能
4.新增预装Viper HiFi应用
5.新增远程控制应用开机自启动选项
6.修复USB独占应用从后台关闭后,独占不释放问题
7.修复USB输出切曲开头有几率出现异音问题
8.修复切曲键和暂停播放键焦点问题导致几率性不响应问题
9.优化指示灯显示逻辑
10.优化飞傲音乐USB独占兼容性
11.优化开启ALL TO DSD后切曲冲击声
12.其他性能优化及Bug修复
备注:
1.飞傲播放器×VIPERHiFi深度合作,专属定制调音|DSD定制直通|可免费领取1个月会员
2.网盘播放功能:可前往飞傲音乐-多媒体服务下登录使用
3.远程控制开机自启动功能:可前往远程控制应用-设置下开启
4.第三方应用后台管理功能:可前往设置-电池-应用待机优化和自启动管理下,开启一键优化所有应用和将无需自启动的第三方应用关闭,可有效降低待机功耗
DT11 FW1.0.2 firmware download link
Incremental firmware package:
dt11pack.fiio.net/1.0.1/DT11-ota-1.0.2.zip
Full firmware package:
dt11pack.fiio.net/1.0.1/DT11-update-1.0.2.zip
