I am using IFI Go Pod Maxs (bluetooth IEM adapter) which are capable of LHDC, and when I selected LHDC on the R9 there is no sound coming through the Go Pod Max's. I know there is not a compatability issue between the R9 and the Go Pod Max's because they work perfectly using the LDAC codec. Can you confirm that the R9 should be capable of playing back music using LHDC codec, and provide advice on how to fix this.
Thanks
