DM13-Firmware download FiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:120
Reply:83 Read:40154   2025-01-23 16:26:19
How to update the firmware for DM13: Click here
1. The upgrade process is only about 10 seconds or even shorter. If your device stays in the UPDATE... state, please check whether your USB flash disk and port are connected correctly.
2. If your device stays in the UPDATE... state for more than 5 mins, please try to turn on the D mode switch then turn off. And restart the DM13 to update the firmware again.
Updated at 2025-06-04
Firmware changes are as follows:
1. Fixed the issue where some discs had no sound in the first second
2. Fixed screen brightness memory bug.
3. Fixed bugs in optical and coaxial outputs.
4. Optimized power level display during charging and discharging.
5. Optimized disc-reading experience for certain CDs.
6. Optimized software logic.
Note: This firmware update takes inspiration from classic CD players. After reading a disc, it will first display the CD information. Manual playback is required—press the play button to start music playback.
DM13 Standard version V16 firmware download link:
https://fiio-firmware.fiio.net/DM13/DM13_NoBT_V16.zip
DM13 Bluetooth version V27 firmware download link:
https://fiio-firmware.fiio.net/DM13/%E8%93%9D%E7%89%99%E7%89%88/DM13_BT_V27.zip
83Replies Positive Reverse  GO!
