ECHO MINI-firmware downloadFiiO Community| FiiO forum| FiiO product official communication platform
Reply:418 Read:426238   2025-01-21 09:34:38
1. Unzip the file and copy the HIFIEC25.img file to the root directory of the ECHO MINI's internal memory. Safely eject the device and restart it to begin the automatic upgrade.
3. The ECHO MINI is available in two versions with different internal storage capacities: 8GB and 512MB. Since the firmware for these two versions differs, you must copy
the corresponding firmware file for a successful upgrade based on the storage size of your device. How to identify the correct firmware:
For the 8GB version, copy the firmware file named "HIFIECXX.IMG".
For the 512MB version, copy the firmware file named "MINIVXX.IMG".
If you are still unsure which version you have, you can copy both firmware files into the root directory of the device's internal storage.
The device will automatically detect the correct one and proceed with the upgrade.
Video instruction: https://www.youtube.com/watch?v=BaydW5Y8ouM
Updated at 2026-10-24
ECHO MINI V4.0.0 firmware changes are as follows:
1. Added M3U playlist functionality.
2. Fixed incorrect album sorting for certain tracks.
3. Optimized playback response speed.
4. Other system optimizations.
1.新增M3U列表功能
2.修复部分歌曲专辑排序有误的问题
3.优化歌曲播放的响应速度
4.其它系统优化
ECHO MINI V4.0.0 firmware download link: Click here
Updated at 2026-8-31
ECHO MINI V3.9.0 firmware changes are as follows:
1. Fixed an issue where tracks could not be added to Favorites in certain situations.
2. Optimized the display of ID3 tags.
3. Other system optimizations.
Note: This update package contains firmware for two different versions. Please follow the standard upgrade guide to proceed. The system will automatically detect and apply the correct firmware for your device.
1.修复部分情况下无法添加“我喜欢"的问题
2.优化歌曲ID3信息显示
3.其它系统优化
注意:这次两个版本的固件放在了一起,按照教程升级固件即可,系统会自动识别出需要的固件。
ECHO MINI V3.9.0 firmware download link: Click here
Updated at 2026-7-27
ECHO MINI V3.8.0 firmware changes are as follows:
1. Fixed an issue where switching to the previous track would trigger an "unsupported format" error for OGG files.
2. Fixed an issue where ID3 tags were not displayed for some APE files.
3. Fixed an issue where ID3 tags were not displayed for WMA files.
4. Fixed an issue where album art was not displayed for some MP3 files.
5. Other system optimizations.
1.修复OGG格式在切换上一曲时会提示不支持的问题
2.修复部分APE格式ID3信息不显示的问题
3.修复WMA格式ID3信息不显示的问题
4.修复部分MP3格式封面不显示的问题
5.其他系统优化
The ECHO MINI is available in 8GB and 512MB versions. Since there are some functional differences between the two versions, the firmware also differs accordingly. The method to distinguish the firmware is as follows:
Firmware with "HIFIEC" in the filename is for the 8GB version.
Firmware with "MINI" in the filename is for the 512MB version.
If you copy the wrong firmware file, the upgrade interface will not appear when you try to update the device. Therefore, if this happens, please check whether the firmware filename is correct. If it is incorrect, simply re-copy the correct firmware file and try again.
注:
ECHO MINI存在8GB和512M版本,由于两个版本在功能上有些差异,所以固件也会有所不同,固件区分方法如下:
固件名称带“HIFIEC”的为8GB版本的固件;
固件名称带“MINI”的为512M版本的固件。
如出现固件拷贝错误的情况,固件升级时机器不会弹出升级界面进行升级,所以如果出现类似的情况,请检查固件名称是否正确,如有误,重新拷贝正确的固件即可。
ECHO MINI(8G) V3.8.0 firmware download link: Click here
ECHO MINI(512M) V3.8.0 firmware download link: Click here
Updated at 2026-7-7
ECHO MINI V3.7.0 firmware changes are as follows:
1. Added new Button C Mode.
2. Fixed an issue where ID3 tags for some FLAC format songs were not displayed.
3. Optimized the previous track switching logic.
4. Optimized the media library loading speed.
Button C Mode: Single press/Double press the Previous/Next track button to adjust volume; long press the Previous/Next track button to switch songs.
Previous track switching logic: When the current track has played for less than 3 seconds, switching to previous track will skip to the actual previous track and start playback;
when the current track has played for more than 3 seconds, switching to previous track will restart the current track from the beginning (0:00).
1.新增按键模式C模式
2.修复部分flac格式歌曲ID3信息不显示的问题
3.优化上一曲切曲逻辑
4.优化更新媒体库加载速度
5.其它系统优化
注:
C模式:单击/双击上下曲键调节音量,长按上下曲键切曲
上一曲切曲逻辑:在当前曲目播放到3S以内时,点击上一曲会跳转到当前曲目的上一曲并开始播放;而当曲目播放超出3S后,点击上一曲则会跳转到当前曲目的0S开始重新播放。
注:
ECHO MINI(8G) V3.7.0 firmware download link: Click here
ECHO MINI(512M) V3.7.0 firmware download link: Click here
Updated at 2026-6-4
ECHO MINI V3.6.0 firmware changes are as follows:
1. Fixed the issue of incorrect album sorting for m4a format.
2. Fixed an issue where the device would occasionally freeze when accessing Favorites.
3. Fixed an issue where Media Library could not be updated on some micro-SD cards.
1.修复M4A格式专辑排序错乱的问题
2.修复个别情况下进入我喜欢会出现卡死的问题
3.修复部分TF卡更新媒体库不成功的问题
4.其它系统优化
ECHO MINI V3.6.0 firmware download link: Click here
Updated at 2026-5-15
ECHO MINI V3.5.0 firmware changes are as follows:
1. Added CD number sorting under album sorting.
2. Fixed an issue where playback position was not remembered when playing from Favorites.
3.Other system optimizations.
Notes: CD number sorting is added to album sorting. The sorting priority is: CD number—Track number—File name.
1.新增专辑排序下的CD号排序
2.修复在“我喜欢”里播放时不能记忆续播的问题
3.其它系统优化
注:专辑排序新增CD号排序,排序逻辑顺序为CD号--音轨号--文件名。
ECHO MINI V3.5.0 firmware download link: Click here
Updated at 2026-4-24
ECHO MINI V3.4.0 firmware changes are as follows:
1. Added new button mode for track control.
2. Improved battery level display accuracy.
3. Other system optimizations.Note:
Button Mode A: Short press to adjust volume, long press to fast forward/rewind,
double press to switch tracks.
Button Mode B: Short press to switch tracks, long press to fast forward/rewind,
double press to adjust volume.
1.新增短控切曲按键模式
2.优化电量显示准度
3.其它系统优化
注:
按键模式A:短按调节音量,长按快进快退,双击切曲;
按键模式B:短按切曲,长按快进快退,双击调节音量;
ECHO MINI V3.4.0 firmware download link: Click here
Updated at 2026-3-27
ECHO MINI V3.3.0 firmware changes are as follows:
1. Added support for displaying ID3 tags for DSD format.
Note: DFF format does not support ID3 tag display.
2. Fixed an issue where updating the Media Library would accidentally clear Favorites.
ECHO MINI V3.3.0 firmware download link: Click here
Updated at 2026-2-10
ECHO MINI V3.2.0 firmware changes are as follows:
1. Fixed the issue where clicking to play a song might occasionally cause song skipping.
2. Optimized the smoothness of level-4 and level-5 volume.
ECHO MINI V3.2.0 firmware download link: Click here
Updated at 2026-1-16
ECHO MINI V3.1.0 firmware changes are as follows:
1. Added the function of supporting the playback of all songs in genre classification;
2. Optimized the scheduled shutdown function;
1.新增流派分类支持播放所有歌曲
2.优化定时关机功能
3.其他系统优化
ECHO MINI V3.1.0 firmware download link: Click here
Updated at 2025-12-26
ECHO MINI V3.0.0 firmware changes are as follows:
1. Added the function of long pressing the menu button to quickly add/remove songs from the Favorites list.
2. Added support for fast-forward/rewind operations when the screen is off.
3. Renamed the original Playlist section on the home screen to Media Library.
1.新增长按菜单键快速添加/取消【我的最爱】功能
2.新增在熄屏状态也支持快进快退操作
3.修改主页原【播放列表】名称为【媒体库】
4.其他系统优化
Note:Since the update is extensive, the firmware upgrade will first format the internal memory and Favorites list. It is recommended to back up your songs before upgrading.
ECHO MINI V3.0.0 firmware download link: Click here
Updated at 2025-12-03
ECHO MINI V2.8.0 firmware changes are as follows:
1. Added lyrics display switch.
2. Added channel balance adjustment.
3. Fixed an issue where changing the drive letter would clear the favorites list.
4. Fixed a rare crash issue when updating the media library.
5. Optimized song navigation speed.
6. Miscellaneous system optimizations.
1.新增歌词开关
2.新增声道平衡调节
3.修复更换盘符后会清空收藏夹歌曲的问题
4.修复更新媒体库有概率出现死机的问题
5.优化歌曲导航速度
6.其他系统优化
ECHO MINI V2.8.0 firmware download link: Click here
Note:Since the update is extensive, the firmware upgrade will first format the internal memory. It is recommended to back up your songs before upgrading.
Updated at 2025-11-19
ECHO MINI V2.7.0 firmware changes are as follows:
1. Added a function of swapping volume buttons.
2. Fixed the issue where the album cover might not be displayed when switching tracks.
3. Miscellaneous system improvements.
1.新增音量按键调换功能。
2.修复切曲有概率出现封面不显示的情况。
3.其他系统优化。
ECHO MINI V2.7.0 firmware download link: Click here
Updated at 2025-10-25
ECHO MINI V2.6.0 firmware changes are as follows:
1. Fixed the issue of incorrect album sorting for M4A format files.
2. Optimized compatibility to support displaying ID3 information in RIFF format.
1.修复M4A格式专辑排序乱序的问题。
2.优化兼容支持RIFF格式ID3信息显示。
3.其他系统优化。
ECHO MINI V2.6.0 firmware download link: Click here
Updated at 2025-09-30
ECHO MINI V2.5.0 firmware changes are as follows:
1.Fixed the noise problem that occurs occasionally;
2.Optimized the shuffle playback logic;
3.Optimized the flash memory capacity display logic;
4.Miscellaneous system improvements.
1.修复有概率出现杂音的问题
2.优化随机播放逻辑
3.优化内存容量显示逻辑
4.其他系统优化
ECHO MINI V2.5.0 firmware download link: Click here
Updated at 2025-08-21
ECHO MINI V2.4.0 firmware changes are as follows:
1. Added USB DAC function.
(How to use USB DAC function: https://www.youtube.com/watch?v=vtd5MvgD4xw  )
2. Added folder skip function.
3. Optimized DAC DRE parameters.
1. Since the update is extensive, the firmware upgrade will first format the internal memory. It is recommended to back up your songs before upgrading.
2. The USB DAC function allows the ECHO MINI to be connected to a smartphone or computer and used as a USB DAC and headphone amplifier.
3. When connected to a computer or smartphone via OTG, the ECHO MINI will automatically display a prompt to select between USB DAC mode or data transfer mode, and the selection will be remembered as default.
4. The USB DAC function is driver-free, which supports a 48kHz sampling rate, and currently does not support Exclusive USB Audio Access Mode.
5. When using the USB DAC function, the connected smartphone or computer will charge the ECHO MINI. So it is recommended to fully charge it before connecting to a smartphone.
1.新增USB DAC功能
2.新增文件夹跳曲功能
3.优化DAC DRE参数
4.其他系统优化
提示:
1.本次升级会格式化本机内存,请注意备份内存曲目;
2.USB DAC功能,可以将ECHO MINI作为手机或电脑USB解码耳放使用;
3.接入数据线后会自动弹出USB DAC和数据连接选择项,选择后会记忆默认;
4.USB DAC功能无需安装驱动,免驱使用,支持48kHz采样率,暂不支持独占使用。
5.使用USB DAC功能时连接手机时,会消耗手机的电,建议充满电再使用。
ECHO MINI V2.4.0 firmware download link: Click here
Updated at 2025-07-09
ECHO MINI V1.8.0 firmware changes are as follows:
1. Added 3 new UI themes.
2. Fixed screen flickering at low brightness.
3. Fixed the issue where some ID3 tags displayed as unknown in the playback page.
4. Fixed random crashes during firmware updates.
5. Fixed character dropouts in certain tracks.
6. Optimized some language translations.
7. Other system optimizations.
1.新增3款主题UI。
2.修复低亮度时屏幕闪烁的问题。
3.修复部分ID3信息在播放界面显示为未知的问题。
4.修复有概率出现升级闪退的问题。
5.修复部分歌曲出现掉字的问题。
6.优化部分语言翻译。
7.其他系统优化。
ECHO MINI V1.8.0 firmware download link: Click here
How to switch the UI theme:
Go to System Settings-Interface Style for switching.
Updated at 2025-06-09
ECHO MINI V1.7.0 firmware changes are as follows:
1. Added custom EQ functionality.
2. Modified startup to cancel automatic media library updates.
3. Fixed support issues with some OGG formats.
4. Optimized display of certain special characters.
5. Optimized cover lyrics display.
6. Other system optimizations.
1.新增自定义EQ
2.修改开机取消自动更新媒体库
3.修复部分OGG格式不支持的问题
4.优化部分特殊字符的显示
5.优化封面歌词的显示
6.其他一些系统优化
ECHO MINI V1.7.0 firmware download link:
https://fiio-firmware.fiio.net/ECHO%20MINI/ECHO%20MINI%20V1.7.0.zip
How to enable custom EQ:
Go to Music Settings-Equalizer,-Custom to enter the custom EQ adjustment page.
Custom EQ operation instructions:
Volume +/- button: adjust dB value up/down
Menu button: switch the frequency point
Play button: save the Custom EQ
Note: Custom EQ only supports 5 bands fixed frequency, which are 100, 300, 1K, 3K, 10K.
Updated at 2025-04-30
ECHO MINI V1.6.2 firmware changes are as follows:
1. Modified artist display to prioritize track artists
2. Fixed audio clipping issue at the beginning of track playback
3. Improved shuffle play logic
4. Optimized album art display
5. Miscellaneous system optimizations
1.修改艺术家显示优先歌曲艺术家的问题
2.修复歌曲开头掉字的问题
3.修复随机播放模式下手动选曲后会出现按照固定顺序播放的问题
4.优化专辑图片显示
5.其他一些系统优化
ECHO MINI V1.6.2 firmware download link:
https://fiio-firmware.fiio.net/ECHO%20MINI/ECHO%20MINI%20V1.6.2.zip
Updated at 2025-04-18
ECHO MINI V1.5.0 firmware changes are as follows:
1. Added Retro EQ style;
2. Modified font display for shutdown logo;
3. Modified artist categorization to prioritize "Album Artist";
4. Fixed the screen flickering issue when switching tracks at low brightness;
5. Optimized shuffle algorithm to now remember previous track;
6. Optimized ID3 tag display for songs;
7. Miscellaneous system improvements.
1.新增复古EQ
2.修改关机LOGO显示字体
3.修改艺术家分类优先专辑艺术家
4.修复低亮度时切曲有屏幕闪烁问题
5.优化随机播放规则,可记忆上一曲
6.优化歌曲的ID3信息显示
7.其他一些系统优化
ECHO MINI V1.5.0 firmware download link: https://fiio-firmware.fiio.net/ECHO%20MINI/ECHO%20MINI%20V1.5.0%20.zip
Updated at 2025-03-24
ECHO MINI V1.4.6 firmware changes are as follows:
1. Changed the playback page gear to rotate counterclockwise.
2. Added a setting function for the screensaver clock.
3. Fixed the issue where a slight whistling noise existed in the backlight chip when the screen was on.
4. Optimized the reading and display of certain lyrics libraries.
5. Optimized the sorting of songs in the playlist page by filename.
6. Changed the sorting of songs in the album list by track number.
1.修改播放页齿轮为逆时针转动;
2.增加屏保时钟的设置功能;
3.修复亮屏时背光芯片有轻微啸叫声问题;
4.优化部分歌词库的读取显示;
5.优化播放列表页歌曲以文件名排序;
6.修改专辑列表歌曲以音轨号排序;
7.其他一些系统优化。
ECHO MINI V1.4.6 firmware download link: Click here
Updated at 2025-02-24
ECHO MINI V1.4.0 firmware changes are as follows:
1. Added cover display and full-screen lyrics function;
2. Added fast forward and backward function;
3. Optimized the total volume level of the system to 120;
4. Added “My Favorites”  song collection functionality in file browser option;
5. Fixed the the issue where there is a probability of having a “pop” sound when turning off the player;
6. Miscellaneous system improvements.
1.增加封面显示和全屏歌词功能;
2.增加快进快退功能;
3.优化系统总音量级为120级;
4.文件浏览项增加"我喜欢"收藏保存功能;
5.修复关机时有概率出现"pop"声;
6.其他一些系统优化
Note:The cover display and fast forward and rewind functions can
be enabled in the music settings.
There is the function change of the volume buttons when the fast forward and rewind function is enabled:
A. When the fast forward and rewind function is enabled:
Screen on
1. Short press the volume buttons to adjust the volume one step at a time. After the volume bar pops up, hold the volume buttons to adjust the volume continuously.
2. Double- click the volume buttons to switch songs.
3.Hold the volume button to fast forward or rewind.
Screen off :
1. Short press the volume buttons to adjust the volume one step at a time;
2. hold the volume buttons to adjust the volume continuously.
3. Double- click the volume buttons to switch songs.
B. When the fast forward and rewind function is closed:
Screen on:
1. Short press the volume buttons to adjust the volume one step at a time; After the volume bar pops up, hold the volume buttons to adjust the volume continuously.
2. Hold the volume button to switch songs.
Screen off:
1. Short press volume buttons to adjust the volume one step at a time.
ECHO MINI V1.4.0 firmware download link: Click here
Updated at 2025-02-15
ECHO MINI V1.3.0 firmware changes are as follows:
1.Adjusted song title display from filename to ID3 tags;
2.Changed clock display from 12-hour to 24-hour format;
3.Fixed the issue where the music library may update if the device is charging while powered off;
4.Improved audio playback to prevent missing characters at the beginning of the song;
5.Improved the functionality of song collection in "My Favorites";6.
1.更改歌曲名显示逻辑:由文件名调整为ID3信息;
2.更改时钟显示:由12小时制调整为24小时制;
3.修复关机充电后有概率重新更新歌曲库;
4.优化播放歌曲开头“掉字”问题;
5.优化“我喜欢”收藏保存功能;
6.其他性能优化
ECHO MINI V1.3.0 firmware download link: Click here
Updated at 2025-01-24
ECHO MINI V1.2.7 firmware changes are as follows:
1. Optimized song file sorting.
2. Fixed the issue where the clock setting sometimes reset after a reboot.
3. Fixed the issue where the "Charging" characters would flash when charging the device during the power-off state.
4. Optimized Bluetooth auto-reconnect function after shutdown and power-on.
1.优化歌曲文件排序;
2.修复时钟设置重启后有时会复位的问题;
3.修复关机充电时,“充电中”字符闪烁问题;
4.优化关机后再开机蓝牙回连功能。
ECHO MINI V1.2.7 firmware download link: Click here
Updated at 2025-01-21
ECHO MINI V1.2.5 firmware changes are as follows:
1. Added Gain settings (press the menu button in the playback interface to access and adjust it in the playback settings menu).
2. The power-saving mode is enabled by default to 5 minutes.
3. Fixed the issue where filter settings were not saved after shutdown.
4. Fixed the issue where shuffle loop play within folders was not working.
5. Fixed the issue where automatic fast-forwarding and noise may occur during playback.
6. Fixed the issue of where popping sound may occur during Bluetooth playback.
7. Removed the "Warning" symbol from the pop-up prompt.
1. 增加增益设置(播放界面下按菜单键在播放设置菜单中设置);
2.默认打开省电模式开关,默认为 “5分钟”;
3.修复滤波器设置关机后不保存的问题;
4.修复不能在文件夹内随机循环播放的问题;
5.改善概率性出现播放自动快进及杂音问题;
6.修复蓝牙播放有概率性爆音;
7.取消提示弹窗的“警告”符号。
ECHO MINI V1.2.5 firmware download link: Click here
418Replies Positive Reverse  GO!
