JM21-firmware downloadFiiO Community| FiiO forum| FiiO product official communication platform
Reply:62 Read:74935   2024-12-18 16:41:29
How to update the firmware of JM21: Click here
Note: If you would like to get the download link of the old firmware, please provide the SN code of your device to support@fiio.com. It is recommended to use the latest firmware version for your device.
Updaed at 2026-11-13
Please note: Ensure that more than 6 GB of internal storage is available to prevent the update from failing. This firmware update includes numerous changes and requires a full update package of approximately 1.73 GB. Please allow some time for the download and installation to complete.
JM21 FW1.1.3 firmware changes are as follows:
1. Added a force landscape mode for the home screen.
2. Added background standby optimization and auto-start management for third-party apps.
3. Added album art and ID3 information display in Bluetooth Receiver mode.
4. Added a Phone Decode Mode option under USB DAC working modes.
5. Added lock screen styles.
6. Added ultiple vinyl-style playback interfaces to FiiO Music.
7. Added an option to use a single press of the Multifunction button to enter or exit Cassette/POD mode.
8. Added an option for the HOLD switch to take effect only when the screen is off.
9. Added adjustable SPDIF output volume.
10. Added an option to start the remote control app automatically at startup.
11. Improved audio/video synchronization in USB DAC mode.
12. Improved an issue where pops could occasionally occur when changing tracks with ALL TO DSD enabled.
13. Improved USB exclusive output compatibility.
14. Improved compatibility with some chargers.
15. Fixed an issue where Bluetooth Transmitter volume adjustment could occasionally become unresponsive.
16. Fixed an issue where Spotify could occasionally fail to skip to the next track automatically.
17. Fixed an issue where playback speed adjustment did not take effect in Audible.
18. Other performance optimizations and bug fixes.
1. 新增桌面强制横屏模式。
2. 新增第三方应用后台待机优化及自启动管理功能。
3. 新增蓝牙接收模式下显示专辑封面及 ID3 音乐标签信息的功能。
4. USB DAC 工作模式中新增手机解码模式选项。
5. 新增锁屏样式。
6. 飞傲音乐新增多款黑胶唱片风格播放界面。
7. 新增多功能按键单击进入或退出磁带/POD 模式的设置选项。
8. 新增 HOLD 锁定开关仅在息屏状态下生效的设置选项。
9. 新增 SPDIF 数字音频输出音量调节功能。
10. 新增开机自动启动遥控应用的设置选项。
11. 优化 USB DAC 模式下的音画同步表现。
12. 优化开启 ALL TO DSD 功能后,切换曲目时偶发爆音的问题。
13. 优化 USB 独占输出兼容性。
14. 优化与部分充电器的兼容性。
15. 修复蓝牙发射模式下偶发音量调节无响应的问题。
16. 修复 Spotify 偶发无法自动切换至下一首歌曲的问题。
17. 修复 Audible 应用中调整播放速度不生效的问题。
18. 其他性能优化及问题修复。
JM21 FW1.1.3 firmware download link
Full firmware package:   https://jm21pack.fiio.net/1.1.2/JM21-update-1.1.3.zip
Updated at 2026-04-29
JM21 FW1.1.1 firmware changes are as follows:
1. Added RETRO BOX Bluetooth control adaptation.
2. Added community sharing functionality to the system equalizer.
3. Added new retro theme “Pod Mode”.
4. Added May Day Festival themes to Cassette Mode (Note: To ensure the best festival theme effect, some festive themes will not display album art).
5. Optimized an issue of repeated reboots when connecting the power adapter after low-battery shutdown.
6. Fixed an issue of occasional abnormality in Bluetooth transmission.
7. Fixed an issue of occasional low charging current.
1.新增RETRO BOX蓝牙控制适配
2.新增系统均衡器社区分享功能
3.新增全新复古主题“Pod模式”
4.磁带模式新增五一节庆主题
(请注意:为保证节庆主题效果呈现,部分节庆主题将不显示歌曲封面)
5.优化低电关机后接适配器充电反复重启问题
6.修复蓝牙发射几率性异常问题
7.修复充电电流几率性偏小问题
8.其他性能优化和Bug修复
JM21 FW1.1.1 firmware download link
jm21pack.fiio.net/beta/JM21-update-1.1.1.zip
Incremental firmware package:
jm21pack.fiio.net/1.1.0/JM21-ota-1.1.1.zip
Updated at 2025-12-23
JM21 FW1.1.0 firmware changes are as follows:
1. Added Car Mode functionality (Can be enabled via Settings > General).
2.Added the long-press track skip button for fast-forward/rewind function (Supported only by FiiO Music).
3.Added AUTO EQ function to the system equalizer.
4.Added auto-sleep timer option for Remote Control (Can be configured under Remote Control > Settings).
5.Added Christmas, New Year and other festive themes to Tape Mode.Note: To ensure optimal display of festive themes, song covers will not be shown for some themes.
6.Fixed the issue of occasional pop noise during power-on playback for the first time.
7.Fixed the issue of occasional pop noise when switching tracks.
8.Fixed the issue of occasional pitch shifting in Bluetooth receiving mode.
9.Fixed the issue of incomplete status bar icon display.
10.Other performance optimizations and bug fixes.
1.新增车载模式功能(可前往设置-通用-开启车载模式)
2.新增长按上下曲键快进快退功能(仅飞傲音乐支持)
3.新增系统均衡器AUTO EQ功能
4.新增远程控制自动休眠时间选项(可前往远程控制-设置下选择)
5.磁带模式新增圣诞、新年等节庆主题(请注意:为保证节庆主题效果呈现,部分节庆主题将不显示歌曲封面)
6.修复首次播放上电几率性有冲击声问题
7.修复切曲几率性有冲击声问题
8.修复蓝牙接收模式几率性变调问题
9.修复状态栏图标显示不全问题
10.其他性能优化及Bug修复
JM21 FW1.1.0 firmware download link
jm21pack.fiio.net/beta/JM21-update-1.1.0.zip
jm21pack.fiio.net/1.0.8/JM21-ota-1.1.0.zip
Updated at 2025-09-26
JM21 FW1.0.8 firmware changes are as follows:
1. Added spectrum mode, VU meter mode, and multiple cassette themes.(Go to Settings - Global - Tape Mode Theme to select themes.)
2. Added optimized battery charging function.(Go to Settings - Battery to customize maximum charging percentage)
3. Added options for self-defining button function.(Go to Settings -Global - Self-defined Button Functions to choose different button function schemes; when combined with the screen rotation function, buttons will rotate accordingly.)
4. Added DAC DRE function switch.
5. Fixed abnormal playback issue with certain songs after adjusting system EQ.
6. Fixed the issue of occasional high power consumption in standby mode.
7. Miscellaneous performance improvements and bug fixes.
1.新增频谱模式、VU表模式及多个磁带主题(可前往设置-通用-磁带模式主题下选择)
2.新增优化电池充电功能(可前往设置-电池项下设置,自定义最大充电百分比)
3.新增按键功能自定义选项(可前往设置-通用-按键功能自定义下选择不同的按键功能方案,搭配屏幕翻转功能使用时按键也可同步翻转)
4.新增DAC DRE功能开关
5.修复调节系统均衡器后部分歌曲听音异常问题
6.优化待机几率性耗电大问题
7.其他性能优化和Bug修复
Updated at 2025-06-05
JM21 FW1.0.7 firmware changes are as follows:
1. Added remote control functionality (Note: When using screen control, avoid running multiple apps simultaneously, as it may cause low memory issues).
2. Added Cassette Mode (Accessible via the Cassette Mode icon on the desktop/dropdown menu).
3. Added adjustable output volume for system USB (Enabled by default, go to Settings > Audio to adjust it).
4. Added "Use cover image in the same folder" option (When enabled, if a song has no embedded cover, the first image in the same folder will be used as the cover. Go to Settings in FiiO Music to enable or disable it).
5. Fixed occasional charging failure issues.
6. Fixed the issue where audio may be abnormal in Bluetooth transmitting and receiving.
7. Fixed the issue where desktop folders could not be renamed.
8. Fixed the issue where the play/pause button lock function would fail after sleep mode.
9. Fixed the issue where songs on certain NAS servers using WebDAV protocol would fail to play.
10. Improved some UI display effects.
11. Miscellaneous performance improvements and bug fixes.
1.新增远程控制功能
(注:使用同屏控制时,避免同时开多个应用,可能会导致低内存)
2.新增磁带模式
(可从桌面磁带模式图标/下拉菜单进入)
3.新增系统USB输出音量可调功能
(可前往设置-音频选项下设置,默认开启)
4.新增同文件夹任意名称封面选项
(开启后,当歌曲无封面时,将使用同文件夹下第一张图片作为歌曲封面,可前往飞傲音乐设置下选择开启或关闭)
5.修复概率性无法充电问题
6.修复蓝牙发射/接收几率性出现声音异常问题
7.修复桌面文件夹无法重命名问题
8.修复休眠后播放/暂停键锁定失效的问题
9.修复部分NAS服务器WebDAV协议下歌曲无法播放问题
10.优化部分UI显示效果
11.其他性能优化及Bug修复
Updated at 2025-04-21
JM21 FW1.0.6 firmware changes are as follows:
1. Added system PEQ (Parametric Equalizer) feature
2. Added ALL TO DSD feature
3. Added MQA decoding support
4. Added DoP support for USB DAC
5. Added iPhone decoding support in USB DAC mode
6. Added new WiFi sleep mode strategy to optimize standby power consumption
7. Fixed occasional automatic reboot issue when shutting down with OTG cable connected
8. Miscellaneous performance improvements and bug fixes
1. Before connecting an iPhone for decoding, enable the “iOS Device Decoding” switch in the USB DAC settings.
2. The new version adds the “Keep WLAN connection during sleep” option on the WiFi list page. When disabled (default), WiFi will automatically turn off during system sleep and reconnect upon wakeup, significantly reducing power consumption. Enabling this option maintains a WiFi connection during sleep with moderately higher power usage.
1.新增系统PEQ功能
2.新增ALL TO DSD功能
3.新增MQA解码支持
4.新增USB DAC解码DOP支持
5.新增USB DAC模式支持iPhone解码
6.新增WiFi休眠关闭策略,优化待机耗电
7.修复连接OTG线关机机器几率性出现自动重启问题
8.其他性能优化及Bug修复
注1:连接iPhone解码前,需在USB DAC设置下开启“iOS设备解码”开关
注2:新版本在WiFi列表界面新增“在休眠状态下保持WLAN连接”选项。该选项在默认关闭状态时,WiFi在系统休眠时将会自动关闭,并在系统唤醒时自动打开回连,可有效降低系统休眠时的耗电;您也可以开启该选项,在休眠状态下保持WiFi连接,此时休眠休眠耗电较关闭状态下偏大一些
Updated at 2025-01-20
JM21 FW1.0.5 firmware changes are as follows:
1. Added a new function of Double tap to wakeup (enabled in Settings-Global).Kindly note: Enabling this function may slightly increase system power consumption. Please enable it according to your needs.
2. Miscellaneous performance improvements and bug fixes.
1. 新增双击唤醒功能(可前往设置-通用下开启双击唤醒功能)请注意:开启双击唤醒功能后,系统耗电将会略微增加,请根据需求开启使用。
2. 其他性能优化和Bug修复
Updated at 2025-01-09
JM21 FW1.0.4 firmware changes are as follows:
1. Added the feature of removing third-party app desktop icons.
2. Fixed the issue where local playback may pause automatically.
3. Fixed the issue where playback may crash in Pure Music mode.
4. Optimized memory management strategy to improve the smoothness of foreground applications.
5. Miscellaneous performance improvements and bug fixes.
1.新增第三方应用桌面图标移除功能
2.修复本机播放几率性自动暂停问题
3.修复纯音模式几率性闪退问题
4.优化内存管理策略,提升前台应用流畅度
5.其他性能优化及Bug修复
Updated at 2024-12-31
JM21 FW1.0.3 firmware changes are as follows:
1. Added a key lock setting feature (go to Settings > Global > Key-lock Settings to select which keys to lock when the screen is off).
2. Added shutdown charging function.
3. Optimized compatibility of USB Audio output.
4. Optimized stability of Bluetooth decoding mode.
5. Fixed the issue where there might be no output in USB DAC mode.
6. Fixed the issue where it failed to connect to hotspots of certain mobile phones.
7. Fixed the issue where the “disable charging” function would not take effect after a reboot.
8. Miscellaneous performance improvements and bug fixes.
1.新增锁键设置功能(可前往设置-通用-锁键设置下选择熄屏下需要锁定的按键)
2.新增关机充电功能
3.优化USB Audio输出兼容性
4.优化蓝牙解码模式稳定性
5.修复USB DAC模式几率性无输出问题
6.修复无法连接部分手机热点问题
7.修复禁止充电重启后不生效问题
8.其他性能优化及Bug修复
Updated at 2024-11-18
JM21 FW1.0.2 firmware changes are as follows:
1. Fixed the issue where noises may occur in USB output in third-party apps.
2. Fixed the issue where volume adjustment was unavailable in USB output in third-party apps.
3. Fixed the issue where noises may occur when playing DSD over Bluetooth mode.
4. Fixed the issue where the indicator light would automatically turn on after being turned off.
5. Fixed the issue where the indicator light showed red even when fully charged.
6. Added the function of automatic pause after 2 minutes of playback when no headphones are inserted.
7. Improved compatibility of EXFAT cards.
62Replies Positive Reverse  GO!
