BTR17-firmware downloadFiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:136
Reply:46 Read:45925   2024-12-18 16:25:19
How to update the Bluetooth firmware for BTR17: Click here
How to update the XMOS firmware for BTR17: Click here
Updated at 2026-3-19
Changes and improvements in the new firmware are as follows :
1. Fixed an issue where adjusting PEQ filters via FiiO Control in UAC mode did not take effect.
2. Fixed an issue where adjusting the global gain via the PEQ web control could not be saved upon refreshing.
BTR17 Bluetooth V1.28 firmware download link: Click here
BTR17 XMOS V1.36 firmware download link: Click here
Updated at 2026-3-6
BTR17 Bluetooth V1.27 and XMOS V1.34 firmware changes are as follows:
1. Modified the PEQ frequency gain adjustment range to -24dB–12dB;
2. Optimized the anti-touch function for the volume knob when the screen is locked;
3. Fixed the issue where PEQ curve Q values were inconsistent.
BTR17 Bluetooth V1.27 firmware download link: Click here
BTR17 XMOS V1.34 firmware download link: Click here
Updated at 2025-08-26
BTR17 Bluetooth V1.25 and XMOS V1.32 firmware changes are as follows:
Bluetooth V1.25
1. Added bitrate display for aptX Adaptive/Lossless codecs.
2. Modified UI display color for aptX Lossless codec.
3. Fixed the issue where charging could sometimes only reach 60% after enabling charging protection.
XMOS V1.32
1. Fixed the issue where PS5 might not be recognized in UAC 1.0 mode.
1. When playing under aptX Lossless codec, it may take some time (normally around 30 seconds) before stably entering lossless mode. The bitrate in lossless mode will dynamically vary between 1 Mbps and 1.2 Mbps depending on the audio data.
2. The connection quality and signal interference will affect the activation of lossless mode. It is suggested to keep the phone and receiving device as close as possible, and ensure that the phone is connected to a 5GHz WiFi network (or disable WiFi).
蓝牙V1.25
1. 增加aptX Adaptive/Lossless编码下的码率显示
2. 修改aptX Lossless编码的UI显示颜色
3. 修复开启充电保护后充电有概率只能达到60%的问题
XMOS V1.32
1. 修复UAC 1.0模式连接PS5有概率不识别问题
注意事项
1.aptX Lossless编码下播放时,需要等一段时间(一般30s左右)才能稳定进入无损模式。无损模式的码率根据音频数据的不同会在1Mbps~1.2Mpbs间动态变化。
2.信号连接质量以及信号干扰会影响无损模式的开启,建议将手机和接收设备尽量靠近,并确保手机连接的WiFi为5GHz模式(或者关闭手机WiFi)。
BTR17 Bluetooth V1.25 firmware download link: Click here
BTR17 XMOS V1.32 firmware download link: Click here
(XMOS firmware could be updated via MAC now. Connect BTR17 to the MAC via USB and run the APP in the firmware package to update the firmware.)
Updated at 2025-06-09
BTR17 Bluetooth V1.23 and XMOS V1.31 firmware changes are as follows:
1. Added a switch for Bluetooth multipoint functionality.
2. Added the function of double-pressing the knob button to switch to the next track (requires enabling in APP).
3. Added a pop-up window for volume adjustment.
4. Optimized DAC harmonic compensation adjustment.
5. Optimized battery level calculation.
6. Fixed the issue of missing a pop-up notification during LE Audio calls.
7. Fixed the issue of screen flicker that occurred after manually setting the screen timeout.
8. Miscellaneous performance improvements and bug fixes.
1.新增蓝牙一拖二功能开关
2.新增双击滚轮按键切换下一曲功能
(需要在APP里开启)
3.增加音量调节弹窗
4.优化DAC谐波补偿调节功能
5.优化电池电量计算
6.修复LE Audio通话时没有弹窗提示的问题
7.修复手动熄屏一段时间后屏幕会闪一下的问题
8.其他性能优化及Bug修复
BTR17 Bluetooth V1.23 firmware download link: Click here
BTR17 XMOS V1.31 firmware download link: Click here
Updated at 2025-04-09
BTR17 Bluetooth V1.1 firmware changes are as follows:
1. Add USB microphone function
2. Optimize the volume adjustment of prompt tones
3. Optimize the issue of inaccurate battery level display on some mobile phones and computers
4. Optimize the menu operation logic
5. Optimize audio output control
1.增加USB麦克风功能
2.优化提示音音量调节
3.优化在部分手机、电脑上显示电量不准确的问题
4.优化菜单操作逻辑
5.优化音频输出控制
BTR17 Bluetooth V1.1 firmware download link: Click here
How to use the USB microphone function in BTR17: Click here
Updated at 2025-01-06
BTR17 Bluetooth V0.62 firmware changes are as follows:
1. Add volume adjustment in 120 levels.
2. Add custom previous/next track keys function.
3. Add screen rotation function.
4. Allow D.Mode to be enabled when only USB data port is connected in PC and BT modes.
5. Add control of some menu functions through the APP.
6. Update the UI for selected menu items.
7. Improve the issue where some devices cannot enter LDAC during active reconnection or LDAC is only displayed when playing.
8. Fix the problem where a prompt tone may still be heard when the prompt tone volume is set to 0 and the device is turned off.
9. Other performance optimizations and bug fixes.
1.增加音量120级数调节
2.增加自定义上一曲/下一曲键功能
3.增加屏幕翻转功能
4.增加PC、BT模式下只连接USB数据口时也允许开启D.Mode模式
5.增加通过APP控制部分菜单功能
6.更新菜单选中UI
7.改善主动回连部分设备无法进入LDAC或者要播放时才显示LDAC的问题
8.修复提示音音量设为0后关机时还可能听到提示音的问题
9.其它性能优化及bug修复
BTR17 Bluetooth V0.62 firmware download link: Click here
Updated at 2024-11-26
BTR17 XMOS V128 and Bluetooth V0.51 firmware changes are as follows:
1. Improve the noise problem
2. Improve the shutdown charging power display is not correct
3. Improved the problem that after the lock screen wake-up button is set to the power button, the key control function is abnormal under the lock screen (edited)
4. Fix the problem that USB 1.0 mode connection Switch cannot be used (xmos firmware needs to be updated)
Firmware download link and update instruction: Click here
46Replies Positive Reverse  GO!
