BTR17-firmware download FiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:96
Reply:6 Read:1146   Tue Nov 26 16:38:03 CST 2024
BTR17 FAQ:  Click here
BTR17 XMOS V128 and BluetoothV0.51 firmware changes are as follows:
Updated at 2024-11-26
1. Improve the noise problem
2. Improve the shutdown charging power display is not correct
3. Improved the problem that after the lock screen wake-up button is set to the power button, the key control function is abnormal under the lock screen (edited)
4. Fix the problem that USB 1.0 mode connection Switch cannot be used (xmos firmware needs to be updated)
BTR17 XMOS V128 and BluetoothV0.51 firmware download and update instruction: Click here
6Replies Positive Reverse  GO!
