K3 (NEW) driver + firmware help and audio pop + cutoff when no audio is playingFiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:13772
Reply:1 Read:8376   Wed Apr 24 02:31:25 CST 2024
Greetings,
I've recently bought the NEW K3 (2021) and so far I'm happy with it but I do need some help.
First I need help with the driver and firmware of the device. I'm quite confused with what DAC USB driver I should use for the K3. I ended up using the v.5.62.0 from one of your sites https://forum.fiio.com/note/showNoteContent.do?id=202105191527366657910&tid=17 Was that correct or can you provide me the correct download for the driver?
Additionally I'm asking if there is a new firmware available which you could provide me as I did not find a download link.
Second, I don't know if that is a feature or a problem but the K3 decides "shut down(?)" when there is no audio playing on Windows 11. For example, I just played audio and finished playing it, the device then pops once when there is no audio playing however when I decide to play audio again it will then pop again and also take around half a second to start playing sound of the source I already started playing. Is that an issue or is that by design.
I really need answers to these questions and would appreciate your help.
Kind regards
1Replies Positive Reverse  GO!
