KA17-firmware downloadFiiO Community| FiiO forum| FiiO product official communication platform
Reply:123 Read:137787   2024-03-12 15:46:19
How to update the firmware for KA17: Click here
Video:
How to update the KA17 firmware in MAC:
https://www.youtube.com/watch?v=tJirpeW1RXM
How to update the KA17 firmware in Windows computer:
https://youtu.be/dNs2Sc5g2pM
Updated at 2025-08-18
KA17 V2.25 firmware changes are as follows:
1. Optimized the issue where the UAC 1.0 mode might not be recognized when connected to PS5.
2. Optimized the stability of PEQ parameter indicators.
1.优化UAC1.0模式接PS5有概率不识别问题
2.优化PEQ参数指标稳定性
KA17 V2.25 firmware download link: Click here
Updated at 2025-04-29
KA17 V2.21 firmware changes are as follows:
1. Fixed the issue of no output when playing after repairing some EQ filter settings.
2. Optimized the problem of low output volume when connecting a mobile phone in non-exclusive mode with EQ off.
3. Other performance optimizations and bug fixes.
1.修复部分EQ滤波器设置后播放无输出问题
2.优化在EQ关闭状态连接手机非独占模式输出音量偏小问题
3.其它性能优化及bug修复
KA17 V2.21 firmware download link: Click here
Updated at 2024-12-03
KA17 V2.10 firmware changes are as follows:
1. Added PEQ support for 1.0 mode
2. Add spdif output support for PEQ
3. Improve the problem that the EQ volume will become smaller when the iPhone is connected
4. Improve the problem that the side port in non-exclusive mode is connected to the power supply, and the playback volume becomes smaller after the USB is removed and inserted into the main port
KA17 V2.10 firmware download link: Click here
KA17 V2.00 firmware changes are as follows:
Updated at 2024-04-26
1. Added control of PEQ on the website of PC (https://fiiocontrol.fiio.com/).
2. Added high-pass and low-pass filter options for PEQ.
3. Added multiple control options for FiiO Control App, including filters,
    gain, and volume.
4. Added three modes (A/B/C) for the button control, supporting play/pause,
    previous track/next track (not supported Exclusive USB Audio Excess Mode).
5. Fixed the issue where volume would decrease when enabling EQ.
6. Fixed the issue where settings on FiiO Control App cannot be accessed without
    enabling EQ.
7. Fixed the issue where there was no output when playing 32-bit audio in the
    Exclusive USB Audio Excess Mode after enabling EQ.
KA17 V2.00 firmware download link: Click here
KA17 V0.99 firmware changes are as follows:
Updated at 2024-03-06
1. Added the ability to connect to a computer for decoding. The volume on the computer
    can be adjusted and memorized.
2. Added mobile phone USB exclusive mode playback volume with adjustable volume.
3. Added a pop-up prompt for inserting USB into the side port.
4. Fixed the problem that switching EQ in FiiO Control App or on the local machine cannot
    follow in real time.
5. Fixed the problem of incorrect data saving when adjusting EQ custom 3 in FiiO Control
    App.
6. Modify the EQ switching logic. MQA is supported when EQ is OFF. MQA and DSD tracks
    are not supported when EQ is turned on.
7. Modify the filter name.
8. Optimize UI interface.
9. Other performance optimizations.
KA17 V0.99 firmware download link: Click here
123Replies Positive Reverse  GO!
