R9-Firmware downloadFiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:106
Reply:9 Read:8098   Sat Jan 06 14:33:42 CST 2024
How to check the firmware version of R9:
Settings - About device (pull to the bottom) - View version number
R9 supports two upgrade methods:
1. Online upgrade
R9 is connected to WiFi. If a new version is detected, it will prompt a new version
update in the notification bar. Click to enter the update page. You can also go to
the "Technical Support" - "Firmware Upgrade" page and manually click Check for
Updates to confirm whether there is a new version.
2. Local upgrade
Download the firmware from this website and copy it to the machine's built-in storage
or TF card. Enter from Technical Support, click Firmware Upgrade--Local Upgrade,
find the downloaded upgrade firmware package, and click to upgrade.
Notice:
(1) There is no need to decompress the firmware package;
(2) If the upgrade occurs in factory mode and the firmware cannot be detected,
the firmware may be damaged. Press the power button to confirm, select reboot,
and then re-download the firmware and copy it to the machine before upgrading.
Updated at 2024-04-29
The following changes and improvements have been made to the R9 in FW1.0.4:
System Upgrade:
1. Added new PEQ filter types and compressor sound effects for the system;
2. Fixed the issue where it would not respond to the Play/Pause command by the
    RM3 remote control when playing music on Amazon Music;
3. Miscellaneous performance improvements and bug fixes.
R9 FW1.0.4 Firmware download:
Incremental firmware package: Click here
Full firmware package: Click here
Updated at 2024-03-14
The following changes and improvements have been made to the R9 in FW1.0.3:
System Upgrade:
1. Fixed the issue where the popping sound may occur during playback of certain songs.
2. Miscellaneous performance improvements and bug fixes.
FIIO Music Upgrade:
1. Added a Landscape mode for the display (available in Personal - Screen orientation);
2. Added Lab Features - Compressor sound effect (first turn on the Audio Effects in
    Personal - Lab Features, and then go to Equalizer - Sound effects to enable the
    Compressor);
3. Added a new filter type in Parametric Equalizer (available in the PEQ adjusting page);
4. Added control support for FIIO SP3/FIIO KA11/FIIO K19/FIIO KA17.
R9 FW1.0.3 Firmware download:
Updated at 2024-01-24
The following changes and improvements have been made to the R9 in FW1.0.2:
1. Added a brand-new personalized screen saver - Performance Panel (set in the
    menu of Settings-Display-Screen saver-Personalized Screen saver);
2. Fixed the issue where the dropdown menu did not respond after switching back
    from Bluetooth receiving mode to Android mode;
3. Fixed the slight noise issue at the end of some songs when the ALL TO DSD
    function is enabled;
4. Fixed the issue where the Pure Music mode may crash;
5. Fixed occasional abnormal sound issues when cutting DSD tracks in the FiiO
    Music's streaming playback;
6. Miscellaneous performance improvements and bug fixes.
R9 FW1.0.2 Firmware download:
9Replies Positive Reverse  GO!
