Fiio R7 - Optical Input IssueFiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:1258
Reply:8 Read:2572   Sat Jul 22 06:46:10 CST 2023
This is a great product that I want to love, but it basically cant be used as a DAC for a PC user until you fix your issues.
My PC Motherboard is the Asus Crosshair x670e
Issue #1 Optical Input Issue
My brand new Fiio R7 has audio that stutters in and out constantly from the Optical In.
I have tried mutliple optical cables - the issue is not the cable.
I have tried the following sample rate / bit depths and all of them have issue:
44100Hz 16bit
48000Hz 16bit
88200Hz 16bit
9600Hz 16bit
192000Hza 16bit
44100Hz 24bit
4800Hz 24bit
88200Hz 24bit
9600Hz 24bit
Issue #2 USB DAC Mode Latency
 The USB mode has significant latency across all sample rates. I can fix the latency by unplugging and replugging the USB-C cable but it comes back after leaving the USB DAC Mode. It seems that this issue can be solved when you change the sample rate, but it is the act of changing the rate that almost "resets" it to the proper latency. The moment you leave the USB DAC Screen to another mode and come back, it has bad latency again.
8Replies Positive Reverse  GO!
