Note: When you click the links below to download the firmware, it indicates that you have already read and agreed to the Open source licenses.
FiiO USB Audio driver for KA5: Click here
How to update the KA5: Click here
Note:Please disconnect other USB devices, disable other running programs of the computer, and ensure no power outages during the upgrade process!
KA5 V1.70 firmware download: Click here
Updated on 2025-08-22
Changes and improvements about new firmware are as follows :
1.Optimized DAC DRE parameters.
KA5 V1.60 firmware download: Click here
Updated on 2024-09-30
1.Fixed the volume stepping inconsistency issue between IOS 18.0 and other iOS versions.
KA5 V1.40 firmware download: Click here
Updated on 2024-03-12
Fixed the problem that the device may occasionally display an incorrect version number.
KA5 V1.30 firmware download: Click hereor
KA5 v1.30.zip
Updated on 2023-04-15
1. Fixed the issue where the sampling rate is not displayed after the computer enters sleep mode.
2. Miscellaneous bug fixes.
If your KA5 stuck in 'FiiO' after updating the firmware, please burn the firmware following the help in this package for help: Click here
