R7-Firmware DownloadFiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:115
Reply:16 Read:18564   2023-02-11 09:17:10
How to upgrade the R7: Click here
Updated at 2023-11-10
R7 FW1.0.4 Firmware download:
Incremental firmware package: Click here
The following changes and improvements have been made to the R7 in FW1.0.4:
System Updates:
1. Added the remote control function (requires to be used on the latest version of the FiiO Control, V3.14);
2. Added the global PEQ function (PEQ can also work on third-party apps after being enabled);
3. Optimized the logic of indicator light control;
4. Miscellaneous performance improvements and bug fixes.
FiiO Music APP Updates:
1. FiiO Music's new UI is released;
2. Added online feedback for users;
3. Added track information copy function to the song menu button;
4. Optimized the sorting logic under folders;
5. FiiO Labs has added an ID3 editing function to customize song information;
6. FiiO Lab has added new sound effects, which can adjust channel balance, high and low bass enhancement, and stereo expand;
7. FiiO Control has added device firmware push updates and update log functions.
Updated at 2023-5-11
R7 FW1.0.3 Firmware download:
The following changes and improvements have been made to the R7 in FW1.0.3:
1. Added a new function of iPhone decoding under USB DAC mode (After enabling the iOS devices decoding function on the menu of Settings - USB DAC, the device can be connected to an iPhone/iPad, etc. This function should be disabled when connecting to a non-iOS device);
2. Added an option of two volume adjusting modes (please choose the adjusting mode on the menu of Settings-Global-Volume adjusting mode);
3. Added a new function that the audio would fade in when switching input;
4. Optimized the issue where volume adjustment through the touch screen did not take effect in real time;
5. Optimized text misses when switching songs of different sampling rate;
6. Improved the speed of downloading apps in the FiiO application store;
7. Fixed the issue where files in the micro SD card may stutter;
8. Fixed the issue where the light would be blue when connecting to the RM3;
9. Fixed the issue where the playback would fail in the Audible app;
10. Miscellaneous performance improvements and bug fixes.
Updated at 2023-2-11
R7 FW1.0.1 firmware download: Click here
The following changes and improvements have been made the FW1.0.1:
1. Added: the indicator light follows the display screen on and off;
2. Fixed: the R7 cannot be turned off after USB connected;
3. Fixed: the MQA icon is not displayed in the status bar when playinng MQA tracks through the Tidal app;
4. Fixed Roon Ready's sound dropping problem in the first play and occasional crashing problem;
5. Optimized the bottom touch button logic: the touch button operation will not cause the screen saver to be exited in the screen saverstate;
6. Other optimizations and bug fixes.
16Replies Positive Reverse  GO!
