KA1-firmware downloadFiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:136
Reply:32 Read:47662   2022-07-09 17:00:46
USB DAC driver
FiiO USB DAC driver: Click here
How to update the firmware: Click here
Updated on 2023-11-2
KA1 V1.3 Firmware Changes and improvements about new firmware are as follows :
1. Newly added user-defined EQ tuning that supports 8 music genres:
   Pop, Blues, Classical, Jazz, Rock, Dance, Metal, and Vocals;
2. Miscellaneous bug fixes.
1. EQ adjustment can be supported on FiiO Control App (Android version) after
   updating the firmware. Please update the FiiO Control APP to latest version first;
2. KA1 firmware update is supported in Windows computer with Win10 or above
   system.
3. To avoid upgrade conflict, please unplug other non-essential USB devices when
   upgrading.
KA1 V1.3 firmware download link: Click here
If you have any problem after installing V1.3, please contact support@fiio.com for help.
Updated on 2022-07-09
KA1 V1.21 Firmware Changes and improvements about new firmware are as follows :
1. Added support for FiiO Control App;
2. Added support for in-line control microphones;
3. Added the setting of turning on/off indicator light;
4. Added the function of USB mode switching.
1. FiiO Control App iOS version does not support the control for KA1.
2. In-line microphone function could be enabled via FiiO Control app. (The function
   will be set after reconnect).
   Some mobile phones(Like Hwawei, iPhone) do not support calling via microphone
   in the headphone of KA1.
   When in-line microphone function is on,  DSD native mode would work only when
   using headphone without microphone.
3. USB 1.0 and USB 2.0 mode could be switched via FiiO Control App. (The function
   will be set after reconnect.)
   USB2.0 is set as default. When using with device like switch, you could switch to
   USB 1.0 mode first.
KA1 V1.21 firmware download link: Click here
32Replies Positive Reverse  GO!
