X5III battery bulge - replacement?FiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:1297
Reply:21 Read:5848   Sun Feb 20 20:58:58 CST 2022
After only 1.5 years, my X5III has a bulge on the back cover. I assume this is the battery that has now generated a gas pocket.
That's disappointing and scary after only 1.5 years, with maybe 50 days "in the field", so it has 50 charge cycles. I have only used a slow charge at 500mA. It still seems to carry a decent charge, but a puffed up LiPo is an explosion and fire liability.
Therefor I'd be grateful for any battery replacement tips.
Where to source a good battery and how to replace it? There seems to be some micro torx screws at one end of the chassis - maybe those are the ones to undo to get the back cover off? I can solder if needed, no problem.
I'll mention that I've had a look at AliExpress which is what comes up in a search, but it looks like a rag-tag selection, and I'm aware that you risk getting used and/or under-capacity batteries with faux lables applied.
TIA!
21Replies Positive Reverse  GO!
