FiiO Control-Download linkFiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:136
Reply:38 Read:264980   2021-05-07 16:28:04
For Android userssearch “FiiO Control” in any application market to download it.  Or directly download the APK files and then copy it to FiiO players or cell phones.
For iOS users, search “FiiO Control” in App Store to download it.
PEQ Settings Instructions for FiiO Portable DAC&AMP: Click here
Updated at 2026-07-13
Android version 4.3.0 download link:  Click here
Changes and improvements about new FiiO Control APP are as follows :
1. Added support for K17 R2R
2. Upgraded backend server configuration to 2.0
3. Added quick search connection (Home → Add → Search in the upper right corner)
4. Fixed other known issues
Updated at 2026-03-20
Android version 4.1.1 download link:  Click here
1. Fixed the issue where some interfaces of the streaming media device cannot be opened;
2. Fixed other known issues
Updated at 2026-1-22
Android version 4.0.3 download linkClick here
1. Added AUTO EQ function
2. Bluetooth scanning no longer requires location permissions
3. Fixed other known issues
Updated at 2026-1-16
Android version 4.0.2 download linkClick here
1. Optimized the permission acquisition process;
2. Fixed the issue where network devices would display incorrectly after re-entering when using IP connection;
3. Fixed same screen control related issues;
4.  Miscellaneous issue fixes.
Updated at 2026-1-7
Android version 4.0.1 download linkClick here
  1. UI 4.0
  2. Added support for EH11.
  3. Added support for EH13.
  4. Fixed UI anomalies caused by overlapping status bars and navigation bars
  5. Resolved several known issues.
Updated at 2025-10-21
Android version 3.44.0 download linkClick here
1. Added support of Air Link;
2. Fixed the EQ crash bug on the SP3 BT.
Updated at 2025-10-11
Android version 3.43.9 download linkClick here
1. Fixed the EQ crash bug on the BTR15.
Updated at 2025-09-30
Android version 3.43.7 download link: Click here
1. Added support of media server remote control and indepent casting APP for S15;
2. Added working modes switching for K17;
3. Miscellaneous improvements.
Updated at 2025-09-04
Android version 3.42 download linkClick here
1. Added support for K13 R2R;
2. Fixed the issue where the wrong lanaguage will be displayed for some models.
Updated at 2025-08-08
Android version 3.41 download linkClick here
1. Added support for SP5;
2. Added support for TINY A/B;
3. Added support for MELODY;
4. Added DRE settings for KA15;
5. Added USB connection for BT11 supports  (USB connection is supported for BT11 V1.0.9 and later firmware version . Please upgrade the firmware of BT11 before using the new APP version).
6. Fixed the issue of abnormal volume adjustment when using USB exclusive mode with KA13.
Updated at 2025-07-10
Android version 3.40 download linkClick here
1. Added support for JIEZI;
2. Added support for DSP Audio;
1.新增支持JIEZI.
2.新增支持DSP Audio.
3.其他已知BUG修复.
Updated at 2025-06-19
Android version 3.38 download linkhttps://fiio-firmware.fiio.net/FiiOControl/FiiOControl%20V3.38.apk
1. Added the function of Local Playback support for the SR11.
2. Added the function of control support for the K15.
1.新增支持SR11本地播放功能
2.新增支持K15控制功能
Updated at 2025-06-05
Android version 3.37 download linkhttps://fiio-firmware.fiio.net/FiiOControl/FiiOControl%20V3.37.apk
1.Miscellaneous improvements.
1.修复已知问题
Updated at 2025-04-23
Android version 3.36 download link: https://fiio-firmware.fiio.net/FiiOControl/FiiOControl%20V3.36.apk
1. Added USB OTA update support for BT11
2. Fixed the issue of account registration failure via email
3. Added decoder selection when connecting to Linker devices via IP input
4. Fixed known issues
1.支持BT11使用usb进行ota升级
2.输入ip连接linker设备提供解码器选项
3.修复已知问题
Updated at 2025-04-01
Android version 3.35 download link: Click here
1.Added the function of support link for the K17.
2.Miscellaneous improvements.
1.k17支持link功能
2.修复已知问题
Updated at 2025-03-21
Android version 3.34 download link: Click here
1. Supported new features of BT11 (requires updating BT11 firmware to version 1.0.9 using the iOS FiiO Control app).
2. Added compatibility support for RR11 (inserting RR11 will be recognized as USB Audio).
3. Optimized remote control screencasting smoothness and image quality.
4. Optimized remote control Link function for controlling FiiO Music (requires updating FiiO Music to version 3.2.6 or later).
1.支持BT11新功能(需要使用ios端fiio control应用更新BT11的1.0.9固件)
2.增加了RR11的兼容支持(插入RR11将显示为USB Audio)
3.优化远程控制投屏流畅度和画质
4.优化远程控制link控制飞傲音乐功能(需要更新飞傲音乐3.2.6及后续版本)
Updated at 2025-02-19
Android version 3.33 download link: Click here
1. Miscellaneous improvements.
1. 修复已知问题
Updated at 2025-01-25
Android version 3.32 download link: Click here
1. Optimize the issue of some devices failing to upgrade BTR17 firmware using Bluetooth.
2. Improved remote control.
3. Fixed the issue of wire control failure when adjusting settings using USB products.
4. Miscellaneous improvements.
1. 优化部分手机使用蓝牙升级BTR17固件失败的问题
2.优化远程控制
3.修复使用usb产品调节设置时线控失效的问题
4.修复已知问题
Updated at 2025-01-06
Android version 3.31 download link: Click here
1. Added support for FP3;
2. Fixed the PEQ issue of RETRO NANO;
3. Improved remote control;
Updated at 2024-12-10
Android version 3.30 download link: Click here
1. Added support for RETRO NANO;
2. Added support for S15;
3. Fixed the PEQ issue of BTR15;
4. Improved remote control;
5. Miscellaneous improvements.
Updated at 2024-10-28
Android version 3.29 download link: Click here
  1. Added support for UTWS5 2025;
  2. Added support for BTR17;
  3. Added support for firmware upgrade of KA15.
Updated at 2024-09-14
Android version 3.28 download link: Click here
1. Added support for KA15、BTR11;
2. Fixed the issue where applications of local and selected PEQ had no response on KA17
    and JA11;
3. Added more PEQ filter types for BTR13 and KA17.
Updated at 2024-08-26
Android version 3.27 download link: Click here
1.Add support for BT11.
2.Add support for BTR13.
3.Fixed the issue where some devices failed to upgrade the JA11 via OTA.
4.Miscellaneous improvements.
Updated at 2024-07-29
Android version 3.26 download link: Click here
1. Optimized USB OTA upgrade for JA11.
Updated at 2024-07-19
Android version 3.25 download link: Click here
1. Added USB OTA upgrade for JA11.
Updated at 2024-06-17
Android version 3.23 download link: Click here
1. Added support for JA11.
2. Added support for PEQ sharing. Currently supported devices: JA11, KA17, K19, BTR15, and more
devices will be supported through future updates. In the upper left corner of the EQ setting, select the
preset EQ to use PEQ sharing. Downloading EQ does not require login, but sharing personal EQs
requires registration of a FiiO account.
3. Optimized other user experience issues.
Updated at 2024-04-26
Android version 3.22 download link: Click here
1. Adapted for KA17's new firmware, featuring various new settings. The firmware can
   be obtained from FIIO's official website.
2. Adapted for BTR7's new firmware, introducing new features such as modifying PEQ
   filter types.
3. Added support for FiiO Link control (can directly control FiiO Music or remotely
   control applications via the player; remote control via the player requires
   upgrading to the latest firmware).
Updated at 2024-03-19
Android version 3.21 download link: Click here
1. Added support for K19.
2. Fixed the issue where partial value settings may fail when adjusting the Q value
   for the KA17.
3. Added volume adjustment function for the KA11.
4. Optimized PEQ adjustment logic for the K9 series and Q7.
Updated at 2024-02-05
Android version 3.19 download link: Click here
1. Optimize BTR15 connection;
2. Miscellaneous improvements.
Updated at 2024-01-17
Android version 3.18 download link: Click here
1. Added support for FiiO KA11 and FiiO KA17;
Updated at 2023-12-20
Android version 3.17 download link: Click here
1. Fix the PEQ function of UTWS5, FW3 and FW5;
Updated at 2023-12-15
Android version 3.16 download link: Click here
1. Support for K9 AKM is added.
2. Improve the PEQ function of UTWS5, FW3 and FW5.
3. Fix some problems.
Updated at 2023-12-09
Android version 3.15 download link: Click here
1. Add FiiO BR13 PEQ function and low latency mode.
2. Fix some problems.
Updated at 2023-11-10
Android version 3.14 download link: Click here
1. FiiO BTR15 is added;
2. FiiO Q15 is added;
3. The player remote control and screen sharing function are added. (Support FiiO R7, FiiO M11S, FiiO M15S, need to use with the new firmware of the player.)
Player devices in the same LAN can be added in the player category on the device-adding page.
Supports display of current track information, remote control of player device volume, working mode, system settings, etc.; supports screen sharing.
4. Fix some problems.
Updated at 2023-10-11
Android version 3.12 download link: Click here
1.Added FiiO BR13 control;
2.Added the function of automatically pushing device firmware updates;
3.Added device update log;
4.Added online feedback function in settings;
5.Fixed some issues.
Updated at 2023-9-15
Android version 3.11 download link: Click here
1.Added FiiO KA13 control.
2.Added the function of automatically pushing device firmware updates.
3.Added device update log.
4.Added online feedback function in settings.
Updated at 2023-6-13
Android version 3.10 download link: Click here
1. Added FiiO FW3 control;
2. Fixed the issue where the connection to the BTA30 series would fail;
3. Optimized other functions.
Updated at 2023-4-21
Android version 3.9 download link: Click here
1. Added a new function of controlling the K7 BT;
2. Added second harmonic regulation function for K9;
3. Added PEQ function for the K9Pro/K9Pro ESS;
Updated at 2023-3-15
Android version 3.8 download link: Click here
1. Added a new function of controlling the KA5.
2. Improved the PEQ function of Bluetooth devices.
Updated at 2023-01-16
Android version 3.7 download link: Click here
1. Added controls for the K9, Q11 and FW5;
2. Added PEQ, codec display, and codec selection functions for the UTWS5;
Updated at 2022-12-30
Android version 3.6 download link: Click here
1. Added support for FiiO K9
2. Added support for FiiO Q11
3. Added new functions of PEQ, Bluetooth codec display and selection for FiiO FW5
Updated at 2022-11-14
Android version 3.4 download link: Click here
1. Added control function for the FW5
Updated at 2022-10-07
Android version 3.3 download link: Click here
1. Added control function for the Q7;2. Added charging protection function and optimized the PEQ interface for the BTR7;Note: After entering the PEQ interface and enabling it for the BTR7, long pressing the frequency slider will let you enter the setting of a single frequency point.
Updated at 2022-07-29
Android version 3.1 download link: Click here
1. Added FiiO BTR7 PEQ function (go to the EQ menu for settings);
2. Added online upgrade function for the BTR7;
Updated at 2022-07-05
Android version 3.0 download link: Click here
1. Added app controlling of FiiO BTR7
2. Added app controlling of FiiOxJadeAudio KA1;
3. Improved app controlling of other devices
Updated at 2022-06-22
Android version 2.9 download link: Click here
1. Added app controlling of FiiOxJadeAudio KA2.
Updated at 2022-01-19
Android version 2.8 download link: Click here
1. A new FiiO Control with a big overall upgrade on visual design and UI interactions;
2. Added app controlling of FiiO K9 Pro ESS;
Updated at 2021-10-21
Android version 2.6 download link: Click here
1. Added app controlling of FiiO BTA30Pro;
2. Added app controlling of FiiO KA3;
Updated at 2021-10-11
Android version 2.5 download link: Click here
1. Added app controlling of FiiO UTWS5;
Updated at 2021-08-25
Android version 2.4 download link: Click here
1. Added app controlling of FiiO BTR5 2021;
2. Added app controlling of FiiO K9Pro;
Updated at 2020-12-12
1. Added app controlling of FiiO UTWS3;
2. Added app controlling of FiiO LC-BT1;
Android version 2.3 download link:
Updated at 2020-11-10
Changes and improvements about new FiiO Control APP(Android) are as follows :
1.  Added app controlling of FiiO Q5s Type C
2. Miscellaneous bug fixes.
Android version 2.2 download link:
Click to download
Updated at 2020-10-29
1. Added app controlling of FiiO BTA30;
2. Added app controlling of FiiO UTWS3;
3. Added Bluetooth device renaming function (requires the latest firmware to be installed on the supported devices);
4. Added customized button control function for FiiO BTR5 (requires the latest firmware to be installed on the BTR5);
5. Miscellaneous bug fixes.
Android version 2.1 download link:
Click to download
Updated at 2020-04-11
Since FiiO’s Bluetooth DAC/Amp family was born, an increasing number of users are gradually recognizing the high-fidelity audio of Bluetooth. In order to make Bluetooth devices funnier to be played with, we have added a new function, Bluetooth Devices Control, in FiiO Music app, so that users themselves are able to adjust the channel balance, Bluetooth codec, equalizer, filter, and indicator light as well for their preference.
However, a problem has occurred as they used the devices more frequently. It became annoying because they have to go to the settings menu in FiiO Music every time and click repeatedly until they could finally go to the Bluetooth devices settings.
After considerately though through it, we have managed to develop an exclusive application for Bluetooth devices control. That is FiiO Control, in which you can straightforward make any setting once you open it. It is available for BTR5, BTR3K, BTR3, EH3 NC, LC BT2, Q5s and Q5. What are you waiting for. Download it and take a try so that you will know how amazingly convenient it is!!
Android version 1.2 download link: Click to download
38Replies Positive Reverse  GO!
