FiiO M33 R2R-Firmware downloadFiiO Community| FiiO forum| FiiO product official communication platform
Reply:6 Read:5887   2026-02-06 11:33:31
How to upgrade the M33 R2R: Click here
Updaed at 2026-11-13
Please note: Ensure that more than 6 GB of internal storage is available to prevent the update from failing. This firmware update includes numerous changes and requires a full update package of approximately 1.73 GB. Please allow some time for the download and installation to complete.
M33 R2R FW1.0.5 firmware changes are as follows:
1. Added a force landscape mode for the home screen.
2. Added background standby optimization and auto-start management for third-party apps.
3. Added album art and ID3 information display in Bluetooth Receiver mode.
4. Added a Phone Decode Mode option under USB DAC working modes.
5. Added lock screen styles.
6. Added ultiple vinyl-style playback interfaces to FiiO Music.
7. Added an option to use a single press of the Multifunction button to enter or exit Cassette/POD mode.
8. Added an option for the HOLD switch to take effect only when the screen is off.
9. Added adjustable SPDIF output volume.
10. Added an option to start the remote control app automatically at startup.
11. Improved audio/video synchronization in USB DAC mode.
12. Improved an issue where pops could occasionally occur when changing tracks with ALL TO DSD enabled.
13. Improved USB exclusive output compatibility.
14. Improved compatibility with some chargers.
15. Fixed an issue where Bluetooth Transmitter volume adjustment could occasionally become unresponsive.
16. Fixed an issue where Spotify could occasionally fail to skip to the next track automatically.
17. Fixed an issue where playback speed adjustment did not take effect in Audible.
18. Other performance optimizations and bug fixes.
1. 新增桌面强制横屏模式。
2. 新增第三方应用后台待机优化及自启动管理功能。
3. 新增蓝牙接收模式下显示专辑封面及 ID3 音乐标签信息的功能。
4. USB DAC 工作模式中新增手机解码模式选项。
5. 新增锁屏样式。
6. 飞傲音乐新增多款黑胶唱片风格播放界面。
7. 新增多功能按键单击进入或退出磁带/POD 模式的设置选项。
8. 新增 HOLD 锁定开关仅在息屏状态下生效的设置选项。
9. 新增 SPDIF 数字音频输出音量调节功能。
10. 新增开机自动启动遥控应用的设置选项。
11. 优化 USB DAC 模式下的音画同步表现。
12. 优化开启 ALL TO DSD 功能后,切换曲目时偶发爆音的问题。
13. 优化 USB 独占输出兼容性。
14. 优化与部分充电器的兼容性。
15. 修复蓝牙发射模式下偶发音量调节无响应的问题。
16. 修复 Spotify 偶发无法自动切换至下一首歌曲的问题。
17. 修复 Audible 应用中调整播放速度不生效的问题。
18. 其他性能优化及问题修复。
M33 R2R FW1.0.5 firmware download link
Full firmware package:  https://m33r2rpack.fiio.net/1.0.4/M33R2R-update-1.0.5.zip
Updated at 2026-04-29
The following changes and improvements have been made to the new firmware 1.0.2:
1. Added community sharing functionality to the system equalizer.
2. Added new retro theme “Pod Mode”.
3. Added May Day Festival themes to Cassette Mode (Note: To ensure the best festival theme effect, some festive themes will not display album art).
4. Added “Double press to exit Cassette Mode” option to the multifunction button (Go to Settings > General > Multifunction button to select).
5. Optimized an issue of repeated reboots when connecting the power adapter after low-battery shutdown.
6. Fixed an issue of occasional abnormality in Bluetooth transmission.
7. Fixed an issue of occasional low charging current.
1.新增系统均衡器社区分享功能
2.新增全新复古主题“Pod模式”
3.磁带模式新增五一节庆主题
(请注意:为保证节庆主题效果呈现,部分节庆主题将不显示歌曲封面)
4.多功能键新增双击退出磁带模式选项
(可前往设置-通用-多功能键下选择)
5.优化低电关机后接适配器充电反复重启问题
6.修复蓝牙发射几率性异常问题
7.修复充电电流几率性偏小问题
8.其他性能优化和Bug修复
M33 R2R FW1.0.2 firmware download link
Incremental firmware package:
<a contenteditable="false" rel="noopener noreferrer" target="_blank" class="link rich-text-anchor __anchor-intercept-flag__" data-eleid="16" data-lark-is-custom="true" href="http://m33r2rpack.fiio.net/1.0.1/M33-ota-1.0.2.zip"" data-lark-link="true">m33r2rpack.fiio.net/1.0.1/M33-ota-1.0.2.zip
m33r2rpack.fiio.net/beta/M33-update-1.0.2.zip
Updated at 2026-02-06
The following changes and improvements have been made to the new firmware:
1. Added RETRO BOX Bluetooth control adaptation.
2. Added Auto EQ function for automatic online update of headphone curves. 3. Optimized some charging compatibility issues.
4. Optimized some UI display effects.
5. Other performance optimizations and bug fixes.
M33 R2R FW1.0.1 firmware download link
m33r2rpack.fiio.net/1.0.0/M33-ota-1.0.1.zip
m33r2rpack.fiio.net/beta/M33-update-1.0.1.zip
6Replies Positive Reverse  GO!
