KA15-firmware downloadFiiO Community| FiiO forum| FiiO product official communication platform
Overall posts:136
Reply:38 Read:26841   2024-12-18 16:48:15
KA15 online update tool: https://fiiocontrol.fiio.com/
How to update the firmware for KA15: Click here
Updated at 2026-3-4
KA15 V1.1.6 firmware firmware changes are as follows:
1. Fixed the issue where power saving mode could not be turned off.
Turn off power saving mode: Long press the Volume- button and power the KA15
KA15 V1.1.6 firmware download link and update instruction:Click here
Updated at 2026-2-2
KA15 V1.1.5 firmware firmware changes are as follows:
1. Fixed the issue where adjusting the volume in screen-off state requires pressing the volume buttons twice to take effect.
KA15 V1.1.5 firmware download link and update instruction:Click here
Updated at 2026-1-28
KA15 V1.1.4 firmware firmware changes are as follows:
1.Fixed the issue where the device could not enter sleep mode after the screen turned off.
KA15 V1.1.4 firmware download link and update instruction:Click here
Updated at 2025-12-29
KA15 V1.1.3 firmware firmware changes are as follows:
1. Fixed the issue where connecting to certain phones would prevent the screen from waking up.
KA15 V1.1.3 firmware download link and update instruction:Click here
Updated at 2025-10-08
KA15 V1.1.2 firmware firmware changes are as follows:
1. Added 3 new UI themes, such as VU meter and dynamic spectrum.
2.Optimized the factory reset function to restore customized EQ parameters to factory defaults.
3. Other system optimizations.
KA15 V1.1.2 firmware download link and update instruction:Click here
Updated at 2025-08-01
KA15 V1.0.5 firmware firmware changes are as follows:
1. Added DRE control switch.
2. Other system optimizations.
Note: DRE refers to Dynamic Range Enhancement technology. When enabled, it enhances the audio's dynamic range; when disabled, it helps reduce distortion or coloration.
KA15 V1.0.5 firmware download link and update instruction:Click here
Updated at 2025-05-08
KA15 V1.0.4 firmware firmware changes are as follows:
1. Modified the time to enter sleep mode after stopping playback to 3 minutes, so as to avoid the POP sound caused by entering sleep mode when the playback was paused for a short time.
KA15 V1.0.4 firmware download link and update instruction:Click here
Updated at 2024-12-19
KA15 V1.0.3 firmware firmware changes are as follows:
1. Added the function of renaming and sharing the self-defied PEQ in the web version of FIIO Control.
2. Fixed the issue where PEQ renaming could not be saved in English mode.
3. Miscellaneous performance improvements and bug fixes.
KA15 V1.0.3 firmware download link and update instruction:Click here
Updated at 2024-10-24
KA15 V1.0.2 firmware firmware changes are as follows:
1. Added the function that the language selection page will instantly pop up after performing a factory data reset.
2. Added new Theme 5, a digital dashboard style with power consumption display.
3. Added support for OTA firmware upgrade via the FIIO Control app on the mobile phone.
KA15 V1.0.2 firmware download link and update instruction:Click here
38Replies Positive Reverse  GO!
