FiiO Triple Cables Coming for Sound Quality Improvement!FiiO Community| FiiO forum| FiiO product official communication platform
Reply:0 Read:331   2023-02-04 15:10:49
To meet the different needs of users, FiiO has released three new cables: LA-TC1, LT-LT4 and LT-TC4. Different adapter/charging cables are focused on providing a better, more stable and more reliable experience.
1. LA-TC1
USB-A to Type-C Charging/Data Cable
Excellent adapter cables cannot be separated from good materials. The LA-TC1 is made of professional-grade materials both inside and outside. The inner tinned copper wires keep the cable soft while offering better shielding to greatly reduce external interference; the custom aluminum alloy connector construction is highly robust against wear and tear; its connectors feature 3μ gold-plating, which allows them to be not only oxidation and corrosion resistant; the ends of the cable have been specially designed to be more resistant against bending.
The LA-TC1 allows you to connect equipment with a USB-A port (such as computers) to devices with a Type-C port (such as DACs, mobile phones, and tablet PCs to enable charging and HD data transmission.
* The LA-TC1 is available on our AliExpress Official Store. Click the link below to take it home right away.
https://www.aliexpress.com/item/1005005179142377.html
2. LT-LT4
Type-C to Lightning OTG Cable
The LT-LT4 comes especially for your Apple device. The skin-friendly, yet durable multi-strand cotton mesh sheath effectively survives the wear and tear of daily life by being bent; the connectors of both ends are made of specially-chosen aluminum alloy; it is about 50cm long, which is easy to store.
Using this cable, you can connect a USB DAC to an Apple device for lossless output up to 192k/24bit. Perfect for when connecting products such as FiiO's DAC/Amps to your iOS devices for brilliant results.
* The LT-LT4 is available on our AliExpress Official Store. Click the link below to take it home right away.
https://www.aliexpress.com/item/1005003461497342.html
3. LT-TC4
Type-C to Type-C Charging Cable
Stable and reliable cables provide a satisfactory user experience. The LT-TC4 is made of high-purity tinned-plated pure copper; its braided body is covered with multi-strand cotton meshes; the connectors feature aluminium alloy; it is about 50cm long, which is easy to store.
The LT-TC4 can easily achieve charging, data transfer and other functions. It supports connections between devices with a Type-C port (such as FiiO music players, DACs, and Bluetooth Amps) to devices with a Type-C port (such as mobile phones, tablet PCs and music players) for hi-res music playback.
* The LT-TC4 is available on our AliExpress Official Store. Click the link below to take it home right away.
https://www.aliexpress.com/item/1005003461483817.html
Comparisons of Type-C to Lightning OTG Cables
Comparisons of Type-C to Type-C Charging/Data Cables
