This is a refined specialist with compact elegance.
In a tiny space of 40x15x8mm, there is not only a high-quality DAC, but there is also premium audio amplification to match, both carefully tuned by engineers to truly and faithfully reproduce your music the way it was meant to be heard.
Employed in the KA1 is the ES9281AC PRO chip from ESS, which supports 32bit/384kHz PCM and DSD256. You will surely be able to hear even the finest details within your music!
The KA1 combines USB audio interface, DAC, and amplifier into one package.
When combined with the multi-layered HDI gold-plated PCB it is on, the
result is lower crosstalk, higher efficiency through lower power
consumption, and ultimately high quality pure sound.
The KA1 also supports MQA rendering in
the DAC chip. Moreover, it has colorful RGB light indicators, which not
only feature captivating looks, but also conveniently display the
current audio format and sampling rate. iOS, Android smartphones and
even Windows and Mac computers are all well handled. Dance with HiFi
anytime and anywhere.
Keep features of the KA1 include:
--ES9281AC PRO DAC
--RGB status indicator
--Full support for a variety of devices
--MQA rendering support
--Supports 32bit/384kHz lossless audio
--Supports DSD256
*The KA1 is available on our AliExpress Official Store. Click the link below to take it home right away.
https://www.aliexpress.com/item/1005004125819243.html
